1 - 5 of 5 Posts
The ImpoSTer
I've done gauge cluster swaps on the mk1 focus (SPI to Zetec) to go from no tachometer to one with a tacho and it worked perfectly fine. Not sure if Ford kept the same concept in the newer generations though.
Big Blue 2.0
Gauges will fit no problem, but the speedo is calibrated differently on the ST so the displayed speeds will be off.
Doubt it would work with all the as built data that needs to be programmed into a cluster not to mention the pats system differences in an ST Vs the SE
1 - 5 of 5 Posts
