1 - 3 of 3 Posts
My daughters' '06 ZX5 SES (Canada) has started with the intermittent flashing airbag light. Originally, I had a solid airbag light and the module was no good. I replaced the module a while ago and it worked great up until this past week. I've searched these forums high and low and haven't found a definitive answer. Is there a code reader available that will read the SRS codes on this car? The regular OBD II does not. Thanks!
The airbag light flashes are a code. When you first start the car the airbag light will come on and then flash several times pause flash. Will be a 2 digit code.
Ive found that common issues on older Focus with flashing airbag light are bad clockspring/connector or poor connection at the module.
Good luck
Paul
1 - 3 of 3 Posts
