1 - 4 of 4 Posts
Well today my SVT contracted a wonderfully annoying squeak from the right front corner. The squeak squeaks all the time rough or smooth pavement, if the suspension travels a little bit it squeaks and not once but a series of small high pitched ones. I am at wits end with this car pleas help![scream] [?|] [bash] Recently this corner was repaired with a new strut and hub but the squeak is only happening now.What is the problem?
C
Guest
Sounds like the front sway bar drop links are worn out. Mine were changed because they were worn out and squeeking.
Are those the same as the endlinks because i just replaced those with moog ones. should I try topping off the grease in them?
1 - 4 of 4 Posts
