The skinny:
1. Are my rear drum bearings broken ?
I was getting a lot of squealing noise from the rear drums ( couldn't tell which one ) so I had a look this morning.
The brake shoes look fine. There was a lot of dust.
My observations:
a. First thing I noticed was that there was a lot of grease around the nut, before removing the nut, which, no doubt came from inside the bearing.
b. There was a lot of play in the inner jacket of the bearing, and I mean lateral, off axis.
c. On one of the bearings, the ring that it's supposed to keep the grease in and the dust out was very loose, moving up and down inside the bearing.
This is getting me confused: Once back on the axle, the drums don't jiggle, is it normal for the inner jacket of the bearing to have some play while off the axle ? I guess it's normal there's no play when the drum is tight on the axle.
Could a bad bearing be the cause of the squeaking noise ( when I brake ) ?
Funny enough, now that I've removed the drums and cleaned them a bit, there's no more noise ( 10km or so now ).
I am looking at bearings on ebay and the prices vary by quite a bit. From 40$ for a pair to 45$ for a single one.
Can anybody point an average quality bearing and maybe better one ?
Thank you everyone for any thoughts on this !
My observations:
