I purchased these Spyder ST3 replica headlights and was overall impressed with the quality of the headlights and the output of the stock projectors. The stock projectors appear to be a low beam only version of the Q5 projector that the Mini D2S is based off.
Unfortunately the stock projectors are only low beam, so the halogen high beams were lacking in comparison. I was also not happy with the sharp colorful cutoff and the excess foreground light the stock projectors produced.
I decided to modify and install a pair of Bixenon Morimoto Mini D2S (MD2S) pre production projectors from the retrofit source. I added a custom foreground limited, smoothed the cutoff shields large step, increased the shields movement out of the way for the high beam, and installed the lens from the stock projectors with the spacing adjusted in a way to reduce the cutoffs color. The stock projectors appeared to be a low beam only version of the Q5 projector that the MD2S is based off.
I used a hot knife to cut open a small portion of the headlights backside in order to remove the stock projector.
Measurements of the projector bracket.
Stock projector
The modified MD2S
Connecting the Bi-Xenon solenoid wire.
Time to install the projector and seal the housing.
Stock projector
The modified MD2S
