Inspected my rear brakes and saw a small, spring-loaded plunger on the inside of the rear wheel backing plate at about 7 o'clock position looking at the back surface of the plate. After pulling the drums I saw that when pushed in (from the back side) moves about 1/2" to contact a tang on a lever arm (for the parking brake?). Doesn't seem to be doing anything other than that. Anybody know what this little plunger is for ??????
Also, after doing front brake job, getting a very light brushing or scraping sound at low speed. Last time something like this happened after a wheel bearing job, I found a length (18-24" +/- ???) of small tubing that looked like hard brake line running transverse near the frame close to the front axles. It had become disconnected from a rubber tube and was rubbing against an axle. After reattaching it, the light brushing sound went away. Anybody know what that is? Can't find any info on this item either.
I can take photos if necessary. Thanks.
