1 - 4 of 4 Posts
Good morning, guys!
For whatever reason, I still don't have access to search the forums, so we get a new thread that's probably been covered before.
A long time ago, I replaced the suspension on my 2001 ZX3 with an aftermarket Eibach kit. I remember that the spring compressors I rented from the parts store were much too large and I ended up being required to apply for a Darwin award by modifying some of my existing tools to work.
I'm about to switch out the suspension on a 2002 ZX3 and I'm sure I'll run into the same issue, and no longer have the cobbled-together parts. Has anyone run into this? Any advice on which type to purchase/rent? I see that there are a myriad of choices out there.
https://www.amazon.com/Shankly-Coil-Spring-Compressor-Pieces/dp/B01N6L1QA6/ref=sr_1_1_sspa?crid=2EF75T9Q0E0W6&keywords=spring+compressor+tool&qid=1554296305&s=gateway&sprefix=spring+comp,aps,-1&sr=8-1-spons&psc=1
https://www.amazon.com/Selectec-Macpherson-Compressor-Remover-Installer/dp/B06XKWKFD6/ref=sr_1_2_sspa?crid=2EF75T9Q0E0W6&keywords=spring+compressor+tool&qid=1554296305&s=gateway&sprefix=spring+comp,aps,-1&sr=8-2-spons&psc=1
https://www.amazon.com/ABN-11-5-Strut-Spring-Compressor/dp/B00SX5RSA4/ref=sr_1_3?crid=2EF75T9Q0E0W6&keywords=spring+compressor+tool&qid=1554296305&s=gateway&sprefix=spring+comp,aps,-1&sr=8-3
https://www.amazon.com/Shankly-Spring-Compressor-Tool-Pieces/dp/B01M0UT55Y/ref=sr_1_9?crid=2EF75T9Q0E0W6&keywords=spring+compressor+tool&qid=1554296305&s=gateway&sprefix=spring+comp,aps,-1&sr=8-9
Any advice is always appreciated.
So mote be it
Well for my rears, i had to use this kind:
That being said, i had to use an impact socket between the washers to get it to compress enough to pry the spring out. It would be far easier if i could just remove the lower control arm but mine didnt want to do that.
I cant offer suggestions on the fronts, i always had preinstalled springs on the strut and was able to just swap them whole.
Awesome! I'll look for those. As far as an impact socket between the washers... You mean a pickle fork?
So mote be it
Yeah, i put the hook parts as high on the spring as i could, ran the center through the center hole on the lower bucket of the LCA. Then the pickle fork through the lowest part of the spring, i had to use the impact socket as a spacer between the washers in order to get enough compression on the spring to pry it out of the LCA. With the strut unbolted, i was able to get enough leverage to pry out the spring. Probably not the best explanation but its how i did it.
Not fun though, worried about the spring breaking free the whole time but it worked. Perform at your own risk.
1 - 4 of 4 Posts
