1 - 20 of 20 Posts
Is this what the drivers side motor mount is supposed to look like? Or does it look bad?
not sure but it doesnt look good, how many miles do you have?
to check it rock the motor back and forth ifs its bad it will move a lot
Discussion Starter · #4 ·
80,000km (~48,000mi). The motor doesn't seem to rock when I push on it but it doesn't look very pretty. Can someone take a pic of their mount for comparison.
Wow, that looks pretty rusty.....can't tell if the rubber bushing is good still or not though.
This is what mine looks like, but I upgraded.
Aurelius Pardus
the miles are pretty low for it to go but it is possible you can allways pull it out and inspect the rubber to see if its broke
never run with a broken rubber...
Mine was split like yours and I replaced it with a new oem mount, just in case. Didn't make a bit of difference......
Hmmm
I was just told that I have 2 mounts that were bad. Funny too, cuz they seemed fine until I was in an accident that ruined my front suspension.
So, how difficult are these to change?
Really simple. I had a helper move the motor around for me for the transmission mount though..
Now if I upgrades all 3 motor mounts i will have no movement right, even under hard shifting?
Very slight movement, if at all. Can't exactly watch your motor under hard shifting though.
I've got all 3 on mine, and i remember seeing my engine start up when I had all 3 stock mounts, I couldn't believe how much the engine moved when it started, and now with all 3, it pretty much doesn't move at all when I start it, its amazing. There are tons of benefits to the poly motor mounts, so if you can stand a little bit of vibration at idle, then it'll be worth it to you. Its well worth it to me. One of my favorite mods.
Lower mount is under the engine, drivers side is under the intake box,
passenger mount is to the passenger side of the valve cover.
Guys,
Where under the hood should I look for motor mounts. I was at the dealership last week and ask the guy to fix vibration, and he advised me to replace motor mounts. I drive 2000 SE w/ 125k miles.
Aurelius Pardus
Guys,
read a couple posts up..... loudfocus01 just explained the same thing to me lol...
1 - 20 of 20 Posts
