1 - 3 of 3 Posts
got a problem and hope someone can help.
got a 1.6lx zetec t reg and while drivin the speedo stops readin.
was hopin any1 cud help just incase it is a common fault b4 i remove the instrutment panel and investigate.
any word wud b greetful. thx[race] [race]
Most common problem is the VSS sensor on top of the gearbox that goes bad. Also the headtemp sensor picks up electrical gremlins from the sparkplugwires. They should not run parallel to each other. Guess your mileage/odo only read lines when this happens ?
yeah occasional. thanks. will check the vss sensor on the g/box and the temp sensor. cheers mate
1 - 3 of 3 Posts
