1 - 2 of 2 Posts
I'll email speedhut on Monday but I figured I'd ask here during the weekend.
I did a search and like a lot of people, I get the high pitched buzzing sound from the inverter while on the 'blue' setting. That's fine, I can get over that. I have the stock inverter btw.
I installed the gauges today. I currently have the power hooked up to the orange wire in the gauge harness and grounded to the fuse box. At first the gauges would flicker a little bit sporadically and now they flicker constantly. When set on green you can't tell they flicker all that much but if you look closely you see it. On blue it's VERY obvious and could probably give you a seizure. When I turn down the brightness on the inverter, the gauges dim as per normal and the flickering stops. I'm wondering if it's the inverter. Anyone have an idea??
Discussion Starter · #2 ·
No one eh? I did a google search about this and some other members here mentioned no matter how they tried to wire it, it kept flickering.
1 - 2 of 2 Posts
