1 - 10 of 10 Posts
You don't...
Can't even think of why you would need cruise at 45mph is there like a long freeway with a slow speed limit or something?
Sounds like a "Mykey" setup.
Discussion Starter · #5 ·
I want to clear the mykey. I've looked on YouTube and they don't have a video for a 2011 Ford Focus SE to reset the mykey.
Honestly I've forgotten how you setup the mykey. Have you searched on here?
In order to clear the MyKey key, you need an "admin key" that doesn't have MyKey set up. Turn on the ignition with the admin key, press the Setup button for the I go screen until you get to something like "Clear MyKey" or "MyKey Settings". When you get to that, press Reset (you may have to hold it). If you don't have any admin keys, like if both keys were setup as a MyKey, I'm pretty sure you have to go to a dealer. This the only part I'm uncertain about.
How do I turn off speed control warning at 45 mph on 2011 Ford Focus SE
Hi Cdean3445,
There's info on how to use, activate, and disable speed control on pages 61-63 in your Owner Manual. MyKey info begins on page 67.
Let me know if this helps.
Meagan
1 - 10 of 10 Posts
