Picked up my car after being in for service for a bad hesitation, as well as the land drifting issue.
If I started out in first gear on any kind of incline with the ac on max, it would fall flat on it's face and sometimes stall, unless the RPM's were around 2500.
I picked up the car today, and am having the same issues. They said they replaced the AC compressor and condenser. I didn't see the paper work yet, because there still waiting on back ordered parts to replace the complete steering rack. So I picked up my car until the parts come in.
So my questions are:
1. Do you have any kind of stumbling, or miss fire at idle?
I just don't feel a nice clean idle at all, if that makes any sense.
2. Do you have to feather your gas pedal, while letting out the clutch in 1st gear?
And if so where are your RPM's?
3. Could you get you car moving by letting out the clutch slowly without any gas at all?
The reason I ask, I have to bring the RPM's up to at least 1500 or it will stall (2500 RPM with AC on max). Any other stick shift I've owned you could at least get the car moving by letting the clutch out slowly without any gas at all.
4. Could you start in 2nd gear from a rolling start without feathering the gas?
Once again, any other stick I've owned, you could just drop it into 2nd if rolling without having the car start bucking.
I know I still have a slight hesitation. I just want other manual shift owners input before pushing the issue, when dropping the car to get the rack replaced.
I hope this all makes sense.
-Karl
-Karl
