1 - 7 of 7 Posts
hahaha jut buy whatevr ya cn get .... and if u replace one... just replace aall of them... hit up bestbuy... i spent 200$ on speakers (4) and there alpine... so not to bad... i already have a aftermarket head unit though... anyway
Smitty
replacing the speakers is a pretty easy task. i didn't even use directions to do it cuz you basically can look at the door panel and see how you get it off. there are little screw all around it, and behind the door latch. you can use a rag to get the window crank off if you don't have a power windows ( slid the rag in between the handle and panel and work ur way up with back n forth motions and the clip will pop off) if you have a haynes manual it'll explain everything in better detail. but u'll figure it out
Focused Focus
1 - 7 of 7 Posts
