First of all my car is an 02 SVTF with Jackson Racing SC setup with k&n drop in filter, otherwise stock.
I just replaced the plugs wires and coil with Denso Iridium plugs, MSD 8.5mm wires, and MSD coil from CFM. I went with 1 step colder than stock for svt because of the extra power from SC kit.
The car is running MUCH better than it was with the stock stuff, but still is not idling as smooth as it should be.
This is what denso says about plug gap:
Q. Do I need to set the gap?
A. Generally, no. The DENSO Iridium Power plug comes pre-set with a protective sleeve over the firing end, to protect the gap from accidental alteration. DENSO Iridium Power’s ultra-efficient firing power compensates for normally recommended gap settings that are smaller than the pre-set value. In the cases of vehicle modifications (nitrous, turbo-chargers, super-chargers, high power ignition systems, etc.), some adjustments may be desired. Or, if you prefer to remain consistent with factory specifications, you may adjust. However, please be careful not to place any stress on the fine center electrode during adjustment. You could accidentally break off the very hard, and therefore brittle, tip.
My question is, should I change the gap that came preset because of the SC setup? If so, what gap should they be set to, and how do i check gap without damaging the electrode?
Any help is greatly appreciated!! Thanks.
