1 - 5 of 5 Posts
how do you know what the gap is when installing spark plugs? i know generally you're told how much but is there an equation or formula to figure out what the gap should be depending on what mods you have?
A lot of people here will recommend a .060 gap for NA. .030-something for FI.
I have motorcraft coppers gapped to .060. I feel a little bit of difference on the top end.
What plugs are you using???
denso's. i have a procharger and they're set at .038 now. i want to make sure that's where they are suppose to be or close enough. i've gotten a couple of different responses though that's why i'm asking.
The Librarian
Moved to ”Forced Induction Chat”...
More often than not, the recommended plugs for forced induction are the Motorcraft Copper Plugs (AZFS22C or SP-463).
Gap is somewhere between .035-.040 IIRC.
Denso plugs have been known to melt and cause some pretty bad damage...
Use at your own risk...
The rule of thumb is keep opening the gap until you get misfiring then just close it back down a bit.
Generally the lower your boost the bigger the gap. at 19psi I'm running around a .035 to .040 gap.
1 - 5 of 5 Posts
