Hi, I have done a search and found many people have had an issue with the spare tire and jack. I bought my ZTW used so I am not 100% sure if I have all the correct spare tire parts.
I found this link and it is as close to what I have out of all the other threads I have read in my search on this forum.
http://www.focusfanatics.com/forum/showthread.php?t=108399
I have that foam gerb that looks like it holds the lug wrench and I have two different hooks that are about 4" long and are threaded on the bottoms. The biggest difference is my spare doesn't look like the one in the picture. My spare is the same aluminum rim that I have on the car so that foam piece doesn't fit at all. Does anyone else have a spare that matches the rims on your ZTW or do you think the previous owner replaced the original spare with a aluminum wheel?
It also looks like some sort of plastic piece in the center of the foam gerb with a threaded hook rod through the center of it. I do not have a plastic piece like that. I will take pictures of what I have and maybe someone can tell me if it's correct or I am missing pieces?
Thanks,
Adam
2003 Ford Focus ZTW
Thanks,
Adam
2003 Ford Focus ZTW
