My wifes 2004 se focus with 2.0 zetec recently started sounding like a diesel when under light throttle and idling. I replaced the tensioner thinking that was it, but it still does it. It is SEVERLY worse when air conditioner is on. I am being told AC compressor bearing or compressor itself is bad and trying to fail.
I am leaning towards agreeing because it only has a tiny rattle when ac is off. Also having to deal with a surging idle that makes engine waver almost 3-500 rpms. I thought about mass air meter, but cleaned it and it still does it, although not anywhere near as bad as originally. Should I just burn it to the ground or fix it?
The car still gets good mileage and runs good when going down the highway, although down a bit on power. I still want to clean/replace injectors and put the E3 plugs in it.
Any suggestions would be helpful, but lean on the cheaper side of things first..
