ok guys i got the bottom end together, je pistons eagle rods, but i got a bit of walk...i thought there was a spacer/thrust bearing but there isnt (correct me if im wrong) but it got the cover on that goes over the end of the crank that hooks to the flywheel...am i getting ahead of myself ie the clutch flywheel pushes the crank in or did i drop the ball somewhere? pls help!
btw the oil pan isnt on yet...
ughhhh dammit does that seal between the crank and cover make up for that slack?
