Well proof positive I went from 13.5 to....get this 14.2! holy god this is the only car i've seen this much of a jump and I've done this to almost every car I've owned, all I/0 gauge
I take it you figured out the positive from the alt. lolWell proof positive I went from 13.5 to....get this 14.2! holy god this is the only car i've seen this much of a jump and I've done this to almost every car I've owned, all I/0 gauge![]()
I knew you would read in the 13's instead of the 14+ you said before lol. Yes, my voltage drop is only down to like 13.4V lowest at idle on bursts, but if it's a constant note it drops then goes back up to resting voltage while it's still playing, since the alternator has to have that second or two to up the voltage/current.I'm having the same problem since the car regulates the voltage I'm only sitting at 13.5 13.6...again but it's almost constant...i kept the stock wiring intact just ran 2 grounds and one power all 1/0 gauge...some of these guys who are reading 14+volts must have factory freaks LOL!....I've been in contact with MLA and they are looking into a H/O alt for me![]()
Well, yes it does affect your system, for instance, most amps are rated at 14.4V to put out the power they claim, so if you are below the 14.4V it will output less power, and if your voltage drops then it becomes harmful to your amps and may cause them to overheat or burn up or clip the sound output and harm your subs.Does the voltage make that much of an improvement to the sounnd quality and loudness of a system? even a low powered system?
Alright thanks for the help man only running a 350wat rms amp but thinking about installing a 4 channel amp so I was currious. I drive an 03 zx3 that doesnt have a volt meter in the dash anyway I can meter it?Well, yes it does affect your system, for instance, most amps are rated at 14.4V to put out the power they claim, so if you are below the 14.4V it will output less power, and if your voltage drops then it becomes harmful to your amps and may cause them to overheat or burn up or clip the sound output and harm your subs.
Even low powered systems are affected, but probably not if you have a real low powered system, say only 400RMS total, then your stock electrical probably doesn't even struggle to keep the voltage up. Just depends on your setup and your electrical upgrades and what not.
It can affect sound quality if your amp is clipping the signal, then it will sound distorted or choppy.
Yeah you can measure it with a DMM(Digital Multimeter). I don't have any kind of voltage readout on my dash either, I just use my dmm when I want to view it.Alright thanks for the help man only running a 350wat rms amp but thinking about installing a 4 channel amp so I was currious. I drive an 03 zx3 that doesnt have a volt meter in the dash anyway I can meter it?
