1 - 9 of 9 Posts
I've got a strange clunking sound when I hit bumps in the passenger side....Now I have taken off the wheels and see the problem! The sway bar is hitting the frame. How do I fix this? I have a bunch of photos here to see if that helps....The first set are the problem ones, the second set is the good side for comparison.
Problem:
Now the Good side for comparison:
Help! I'm sick of clunking around!
Yes, that indent is where the bar is hitting....
Anyone have the part number for sway bar end links and bushings? Or know of a good place to get them used? I figured I'd do them all at once instead of one part then the other. When I do that, will I have to do both sides at once or can I just do one side?
What's the probability of my sway bar being bent?
I would do the sway bar end links first and don't put used ones on. Any parts store should be able to get them
1 - 9 of 9 Posts
