Okay. First off, I'm about to rip my hair out. (I'm that guy who just fouled up the easiest mod in focus history.) I JUST installed two new headlights yesterday and both foglights. I got a little giddy and went ahead and did the Fog light mod. Now, I had forgotten the visual diagram in my head and only had a printed sheet with the text on it. Which was probably my biggest mistake. I put them in during the day and didnt really make sure they worked because i was in a hurry and it was thanksgiving. After all is said and done, and it becomes dark out, it's late, and all I want to do is just to get home and crawl into bed and snuggle into the covers and fight off the miserable frigid cold that has become new jersey. I haul all my shit to my car, start it up so it can warm up. 10 mins later I get back outside and go to drive, No headlights. No fog lights. Only the amber running lamps. So I pulled the homemade wire off and put the relay back in. No dice. Fuses? They looked okay mind you it was dark and cold and I didnt have my fuse puller so i could only pull certain ones with a pair of channel locks [smackbum] . juggled the relays around the headlights, nope. Got back on here to search for the problem, and I believe i found the cause but so far no solution. I may have put them in the wrong 2 holes.[scratch] But my problem is, even if the fog light fuse blew, that wouldnt prevent the other lights from turning on, right? I mean i JUST put a fuse back in for my fog lights yesterday because i havent had ones that have worked in 3 months, and I needed the fuse for my jetski. And the lights worked fine. Any help? anybody?
FYI this problem is just the icing on the cake for this car, there are so many things i have to fix and the list just keeps getting longer. Ill ask questions about that later, but for now I need to go to bed. Just figured id let this one problem soak overnight for you geniuses.
Thanks in advance Mr. Lucky guy who helps me fix my car!
[ffrocks]
[ffrocks]
