1 - 7 of 7 Posts
Woke up to this ... anyone know if the zx3 wagons and sedans for mk1 are interchangeable and if manual or powered windows have a difference?
Anyone ever pick one up from a salvage yard? How much did it cost?
Gotta be a ZX3 replacement, others won't match.
I'd guess the manual crank version has different attachments.
PITA - that'll make a mess when it finishes shattering. Lots of vacuuming to do from experience.
I would have to say no as the 2 door models doors are longer than the 4 door model doors.
Vince your Moderator
Didn't someone steal your rims not long ago?
I got a replacement window for my ZX3 for about 80 bucks several years ago, new from a shop. Removal and reinstallation is a snap; once you've got the old debris out, just slide the new window into the slot with the whole thing tipped forward toward the front of the car. A helper guiding the window into the rests on the cable mechanism will help a bunch here. Just pop the front one into its cradle, then the back one, then tighten them back down: you're done!
Carefully lay some good duct tape onto what's left of both sides of the glass then it comes out with a bit less cleanup.
1 - 7 of 7 Posts
