Not sure of the size, but that sounds about right. In '06 Ford did change the strut & the spindle diameter. For '05 Ford changed the ball joint size to a slightly bigger one. Making the '05 spindle different then the others. So the earlier suspension kits fit '00-'05 cars & are more popular then the '06-'11 kits. Seems like when Ford changed the diameter, the suspension manufactors didn't follow suit. So you having a '07 & want to change out your struts & springs to a earlier kit, you'll need to get a pr of '05 only spindles or hit up Karl @ Massive performance to get his "Omni kit''= sleeves that take up the clearence of the bigger diameter spindle & a earlier smaller diameter strut. Just to add, the early & later springs & struts don't interchange= no mix & matching. The later spring have a pigtail on the bottom & the later struts have a platform to except the pigtail. Hope that helps you. Felixthecat[thankyou]I only found 1 thread and some claimed it went from 45MM to 50 MM.
anyone know or confirm this?
Yea= spindle, knuckle, upright, whatever you want to call it.When you say the 2005 has a unique spindle, do you mean steering knuckle?
Toby
Why would you need to swap parts for? You'll only have to change out the struts, ball joints or lower control arms, tie rod ends when they wear. No problem getting those parts.Son of a gun. Since Ford renders parts obsolete after ten years, I'm going to have a heck of a time swapping all this stuff if I ever need to. Thanks for this thread, I didn't realize the suspension parts changed this much over the years.
Toby
Any '05-'11 A-arms work. Plus you can hit up CFM for tubular control arms + the oem ones too. They should be around for a long time, besides thare a crash part, so the aftermarket will pick up the slack.I need this car to last another decade or two, so I'm planning for the worst. I saw Dorman makes control arms, but they aren't my favorite. OEM parts will soon be unavailable.
Toby
