1 - 3 of 3 Posts
So there i was, washing my car and after i took a little drive. Then my oil pressure gauge went down to nothing and my rpms started to go from 2-3k back and forth.. and my car died... so i pushed it to a near parking lot. Poped the hood and it seemed to be hotter than ussual but my gauges showed nothing. A random guy passed by and he asked me what happened, so i told him. He said i needed a new cap for something near the coil pack... and i have no idea what he was talking about.. So after a few more min of talking i decided to try and start it again and ran just fine. So i babied it back home, and there it sits for now. Any idea on what happened??
you got water on something and you should not have and it dried out is mu guess
C2H5OH
#1 "random guy" didn't understand the car and didn't help you. The Focus (and generally any Ford built after about 1994 has a 'distributorless ignition' which) uses a 'coil pack'. On the Focus it looks like this:
random Google image
If water gets inside the towers it can and will reduce the voltage through the spark plug wires, which can cause a misfire or otherwise odd running situations. Being you'd just washed the car it's a good bet something got wet ... a higher than normal idle may suggest the Mass Air Sensor (or air filter) got a bit wet.
To be safe, pull the spark plug boots one by one and see if any are wet. Soak up any water/oil with a rag. The air filter/MAF will dry on it's own.
1 - 3 of 3 Posts
