I have been reading a lot and I think that the snorkle delete with drop in filter may be better than my FSWERKS CAI.
Thoughs?
It is installed on my car and fits perfectly. I have a 14 SE and I had a 13 ST before.Has anyone run the Ford racing snorkel on a non ST? Since the front bumper covers are different does it put it in a spot to pull cold air from? If it does, I will agree 100% that the ford racing kit would be the best option.
Interesting..think that st snorkel is benefitting you? I have a steeda personally which is not the same as those filters as its boxed in. It does have the large hose to pull air from however so I'm curious to know of this snorkel will help with air temps / flow.It is installed on my car and fits perfectly. I have a 14 SE and I had a 13 ST before.
Don't know but the sound is awesome. My car have Tom's work and a FRPP CAI and it pulls harder than my wife 13 SE.Interesting..think that st snorkel is benefitting you? I have a steeda personally which is not the same as those filters as its boxed in. It does have the large hose to pull air from however so I'm curious to know of this snorkel will help with air temps / flow.
The snorkel basically extends from the naked inlet (mount left after a snorkel delete) downward and forward to bring the entry point of the air A) marginally lower but B) more readily accessible from the outside and theoretically makes air flow less restricted by not forcing the intake to suck from at times a space of "dead air" (directly beneath the shroud) when air isn't flowing explicitly into the vicinity of the mounting point.Interesting..think that st snorkel is benefitting you? I have a steeda personally which is not the same as those filters as its boxed in. It does have the large hose to pull air from however so I'm curious to know of this snorkel will help with air temps / flow.
I've done some research on this as well. I have a KN intake system (not just the filter) and have thought about the snorkle delete...I have been reading a lot and I think that the snorkle delete with drop in filter may be better than my FSWERKS CAI.
Thoughs?
