Ok, so I'm 280 miles into my break-in and currently have a issue with 10+ psi of boost.
Once I'm in boost for a good amount of time I start smoking, and immediately after words for quite sometime until I drive normally for a good 5-10+ mins in 2-3k rpm's. Also when this happens I lose vac at idle down to 15 from 22, but after I've drove for a few vac at idle goes back to normal.
I've done alot of testing, but haven't narrowed it down. I'm currently working on crankcase vac/release with pressure (check valve).
AFR is okay, oil pressure is okay..etc etc.
I did a test last week to see what kind of vac in the crankcase I had, and I had zero. Come to find out I had vented the cam cover and had forgot about the oil drains in the head causing no seal for the lower block. I went ahead and sealed the cam cover and now have 5-15in/hg of vac in the block while cruising. When I went into boost I did see around 3-6psi on the lower block. So I'm currently working on venting the block to the dry sump tank with a check valve.
I also drained the 10w 30 royal purple break-in, and am refillingl with 15w 40. A weird thing is when this happens, I can open the dry sump tank and see the oil in it giving off strong smoke fumes as well. I did notice another thing when I drained the oil, I only had about 1- 1.5qts of oil. I've had a few small leaks and hadn't been checking it. Although oil pressure has been fine (I can run as little as a 1/2 qt and still have pressure). The oil leaks have been worked out since.
Oil to hot because I was to low on oil?? I couldnt get a probe into the tank to see what temp it was at.
Other thoughts I have are, to thin of oil and/or not enough drive time on the block with vac on the lower portion to seat the rings. I more or less started right off the bat driving in boost, but didn't have this issue until about a month ago.
Possible saterated oil with fuel from tuning? The smoking/somewhat burning oil in the dry sump tank smells more like fuel then oil..but this could be a royal purple smell as well. I'm currently letting the drained oil settle to see if it seperates, I've already skimmed it for metal and so forth.
After I got the block vented like I want and I still have issues I might swap radiators and run oil through a tranny cooler input on the radiator.
Any input is appreciated. I've done alot of testing but having a hard time narrowing it down.
If someone wants me to post block/build specs I can.
I'm sorry this post is everywhere, I'm extremely tired and am finishing up a 70hr work week, and about to start another 70hr work week in less then 12hrs.
-Jarred
-Jarred
