1 - 3 of 3 Posts
· Registered
Ok as many of you know i just did a clutch swap on my car, runs great, but the only thing is like when i first go out in the morning and start it up and try to get it in first or reverse, it won't go, but if i pump the clutch a few times or just hold it in for about 5 sec then it'll go, not sure what it is, any ideas??
· Focus Hoarder
Check your Bellhousing for any leaks you may of sprung a leak or you have airbubbles in the hydraulics/lines
I'd say re bleed the lines... whats triggering that though is when you pump it it pulls it away which means the bubbles are slowly compressing
1 - 3 of 3 Posts
