Car is a 2000 SPI with about 90k miles on the fuel pump, about 150k miles on the rest of the fuel system. I've read where it's been said that a failing fuel pump with show increased fuel pressure.
I looked up the specifications on the fuel pump and it says:
pressure should be between 35 - 65 psi.
I've noticed that my pressure was always, as noticed in the last year anyway, around 38 - 43 psi.
Just recently I have twice observed pressure to be between 50 - 55psi. The first time it stayed there for the 20 minute trip and didn't drop back down until the car was restarted. The second time it stayed there until I turned the A/C on and the coolant temp dropped back to 192 F - after a while.
During both times above, the fuel pressure jumped to 50+psi after idling for longer than usual and the coolant temp got to 221 F before the cooling fans kicked on.
Is this normal operation of the fuel management system when engine temps increase - causing an increase in fuel pressure or the sign of an aging pump?
