I'm using the factory service manuals from my library to troubleshoot a tranny problem on an '02 Focus SPI. I'm getting DTC's P0750, P0760, P0765, P0770 (solenoid circuit failure for SSA, SSC, SSD and SSE) and I believe the car is operating in the "emergency operating program."
I lost gear function over time (slipping and dropping gears) and the number of DTC's has grown (though at some point I was also getting P0750 for SSB, and now I'm not). Earlier on I replaced SSA and SSB with dealer-new solenoids, and I bought a used (supposedly good) PCM and had a Ford dealer reprogram it for me, but this got me no improvement.
Probably needless to say, I don't have a Ford IDS scan tool or equivalent, just an OBD scanner and multimeter. But it still seems that there are many things I can check this way.
I may end up posting several questions about my test results, but let's start here: Pinpoint Test A3: Check Solenoid Function. The test uses the scan tool to turn each solenoid on and off and asks "Does the solenoid turn on and off when commanded and can solenoid activation be heard?"
With no scan tool, I simply applied battery voltage to each of the installed solenoids. The PWM solenoids (SSC, SSD, SSE) all click audibly. But I can hear nothing from SSA or SSB, even with my ear just half a foot from the solenoids. I note that these solenoids are not PWM.
Should those click if they were good?
