I think you must just have bad luck with radios stations. I cut mine down a long time ago and I can stil get staions from 150miles away.I will warn you that if you cut your own, reception will go to crap. I can only get about half the stations now and I only cut it about half way. If the reception doesn't matter to you, it does look a lot better.
You would be right. Most stations that aren't country in my area are very weak or come from a long distance. Plus I live in a very wooded and mountainous area. If you don't have any of these problems, you shouldn't have any problems with a shorty antenna.I think you must just have bad luck with radios stations. I cut mine down a long time ago and I can stil get staions from 150miles away.
Don't worry. I didn't take it that way. It was a very good point and was worth makingI didnt mean to call you out..just trying make a point...
Yeah, sounds just like the area where you live. I'm in flat central Ohio and cut mine in half and my reception is still about the same. I can drive towards Cleveland and it takes about 100 miles out side of Columbus before I lose stations but then I start to pick up Clevelands. I actually still got all of my preset radio stations when I had the antenna off while I was cutting it[dunno]You would be right. Most stations that aren't country in my area are very weak or come from a long distance. Plus I live in a very wooded and mountainous area. If you don't have any of these problems, you shouldn't have any problems with a shorty antenna.
