1 - 10 of 10 Posts
My Car Wont Shift Into Reverse And Im Furious, Everytime I Step On The Clutch And Pull Back I Go The Same Distance As If My Foot Wasnt On The Clutch And When I Finally Do Get It Pulled Back Far Enough My Gears Grind!!!
Please Help
I have to ask. You are pulling up on the "lock-out ring" right??? Also, if you are, pull the cover off and see if your shifter base may be cracked, or you have a loose or sticking cable.
[werd]. i love it when people try backing up my car and they cant figure it out.
yes im not an idiot i've had the car for 2 years i actually dont even have the ring anymore i put in a short shifter as soon as i bought it and its been fine ever since except this winter is really messed it up...i pulled up on the boot and it looks like when i try n shift into 4th or reverse just sitting there that i cant pull back any farther to find the gear
^^^ Hey I didn't know, you have a low post count and it may have been your first car with a lock-out ring. ( I think the lock-outs are stupid , too )... Try lubing the cables, or you can disconnect them and see if they are frozen or really stiff.
i went to the dealership and asked them what they thought or to see if it would be under warrenty and they said it might be a transmission problem....
Your shift linkage in good repair? could it be sticking?
Discussion Starter #8
they fixed my car at a local shop and he said he bad to bleed the slave line and add new fluid and the car runs great....
what it be like
sometimes by letting off the clutch a little bit will help it fall into gear..
sometimes i catch my svt not wanting to go into reverse
let off the clutch about an inch and it'll go in....
and yeah when i had my ZX3 it was funny watching people trying to put it in gear...
i miss that car
1 - 10 of 10 Posts
