1 - 6 of 6 Posts
My 02 SVTF has some sort of aftermarket short throw shifter and there is a TON of play in it. I know some vehicles you can get new bushings for them, is this the case with the focus? Can someone please point me in the right direction?
I guess I just need to take it out this weekend and actually get a good look at it to see what the problem is.
I know I want to go with the Steeda STS, but dont know if I may have to replace some damaged item in my shifter assy. first.
A peek under the console will tell you what's going on quickly, and it's NOT a big job to remove it. nipping the zip tie that holds the boot to the shifter lever is the most "traumatic" part - you just need a new one to put it together again....
Once you see how it works, most becomes obvious....
Luck!
1 - 6 of 6 Posts
