1 - 2 of 2 Posts
Hi, im looking for a bit of guidance from the community. I just replaced my shift solenoid 'A' and right after I did that i got DTCs P0763 and P0760, which both pretain to shift solenoid 'c'. I checked the resistance and it was 5-6 ohms. It throws the powertrain fault and check engine lights right as I put it in gear. I also checked the voltage coming from the connector that goes right to the solenoid, while the car was running and in gear. Absolutely no voltage there. Any thoughts?
The wires get brittle in the fluid heat and can easily break inside. Likely broke them changing other solenoid. You don't mention which solenoid in which gear, making your no volts statement worthless as proposed. At times it's SUPPOSED to be off. In the case of C it is only on in 4th gear.
1 - 2 of 2 Posts
