Hey there fanatics.
I'm new here, though I've been lurking for a bit. I've got an 02 focus wagon (zetec, auto, I'm guessing the infamous 4F27E) with over 170,000 miles on it. But hey, it still moves, and I enjoy the challenge of high-mileage vehicles (my 86 subaru gl has 228k, and I consider it middle-aged...). The tranny was rebuild only a couple years ago, so it's got a lot few miles on it than the engine.
Recently I've been having a bit of trouble with shifting. Sometimes it is just rough. Other times it almost seems to shift twice, the first time grabbing pretty hard, and the second time going into gear. At highway speeds, it randomly grabs at times it has no reason to shift, almost as if it tries to downshift but then quickly changes its mind. It's been getting steadily worse, and I can't isolate the problem - it can happen at any gear, while under load, while coasting, while hot, cold, etc. I've got no CEL, no other symptoms that can narrow anything down. The one thing that I did notice (and that convinced me that this is definitely a transmission issue) is that if you put the shifter in 1, rather than grab, the tranny slips in and out of gear.
My question has to do with testing shift solenoids. Can I unplug the ECU and apply power to each solenoid's relative pin (it looks like 1, 73, 82, 99, and 102) while listening for a click? Or is this a good way to fry something? And is there anything else I could do to test the shifting mechanisms? This is obviously a mechanical issue rather than electronic (hence the lack of a CEL), so I'm half expecting a worn clutch, but I want to make sure this isn't just a faulty solenoid or something else more easily replaceable.
Thanks in advance for the help!
