1 - 8 of 8 Posts
2000 kona zx3, stick shift, 103,000 miles, borla exhaust.
where should i be shifting for maximum power? there's no yellow or red markings on the stock tach.
thanks
Shot me 3 deer!!!
you should be shifting at about 6500 rpm which is where ur cams run out of juice, maybe a little further so you stay in the powerband when u upshift
thanks. so as a daily driver i'm pretty safe going up to 5k for spirited driving: quick ramp entries, passing, etc.
thanks again
Shot me 3 deer!!!
yup, if you start hearing valve float, then lay off, but thats VERY unlikely!!!
i take mine to 7. and it pulls all the way thru. on the dyno i make max power at 6550
Shot me 3 deer!!!
ur power curve will just drop after 6500 or so, so you can push but ur cams aren't making enough power, so you don't get more power. ur valves/springs will also limit you. once they can't overcome the momentum, the valves don't close all the way and are constantly open. thats called valve float.
1 - 8 of 8 Posts
