1 - 12 of 12 Posts
Car is showing the battery icon quite a bit and and car is stalling. After some starts it doesnt stall at all and others it might stall 2 or 3 times.
Checked the battery- its fine. Checked the alternator- fine too.
What else could it be!?
Just had a new valve installation and timing done, yet it's running really
good-smooth otherwise.
This is the "dropping RPMs in neutral while coasting" problem, I'm guessing.
Yes -thats it , even while its warmed up. So, this is the same issue that others have?
Man, why does this start to happen only after I fix something else?
Anything I can check?
you can check the post to see if they are rusted up. try cleaning them up.
If the battery light turns on but the engine sounds normal, it's most likely the 3-wire harness that plugs into the alternator that's the problem. You'll have to cut off the connector and the inline fuses and replace it with a "alternator pigtail repair kit."
Discussion Starter #9
Is this a DIY kit? Can I replace the 3 wire harness or is this method best?
The wiring pigtail should be soldered and wrapped with shrink tubing. Otherwise it's pretty simple.
1 - 12 of 12 Posts
