1 - 4 of 4 Posts
Hi,
I have a mk1 and have been searching a long time for setting the clock in my car. In the manual doesn't mention any method of setting the clock. There is only + and - signs by the clock but by pressing any of them it doesn't change the clock.
Any idea on how to set the clock is much appreciated.
Don't have the separate clock here, seen where you have one.
Did you try holding both buttons until it went into a set mode?
Yes I even tried by pressing both buttons but nothing happens.
It used to work fine, but was unable to adjust it to summer/winter time, now that I have changed the battery it is set almost 3 hours back! its very annoying when I want to park the car.
Worst case scenario, reconnect the battery on the clock's default time. Or maybe you are only allowed to change the time when the ignition key is in a certain position. Try all combinations.
1 - 4 of 4 Posts
