Well I did my first 2012 Focus oil change today.
Raised car with my old ramps, (about 3.5 inches) Just enough upwards added for me to slide under and remove underbody shield. as said 8 screws, #30 torx head.
The rear of the shield has a slight 'hold. so take out the rear ones first, then front, as the rear will not fall down. (Putting the shield back is a little awkward, as it is hard to figure out where/how the rear sits up so it does not fall down. I had to get it up there, then try to align the FRONT screwholes and after a bit the rear would stay up with whatever it slip into a little bit.) then with the rear not falling down, I could screw up the front first (five) and the rear (three) after.(since i had little room UNDER, I really could not go to the back and see, and as i had no extra light, that also did not help seeing what held the rear up)
I really was stretching out the max to reach the rear shield screws with the minumum height ramps i use.
Anyway the real suprise was unscrewing the drain bolt, [bigcry] and the hot oil squirted out, NOT down, not sideways, STRAIGHT OUT to the rear. falling about only two inches in the first FOOT straight out the side. Suffice to say I was taken by suprise, and spilled some onto the floor before moving the drain pan..
Next time i will have the pan much closer, and perhaps devise some shield or funnel to catch the 'highly motivated' oil before it shoots well PAST the catch basin.
It was funny to be suprised like that. (took awhile to clean the floor up afterwards too.) ((WHY did they make the drain plug sideways???? ))
The other problem was the filter would not budge. i only had one of the plastic bottom grabber tools, and it would NOT turn the stuck on original filter. So I changed the oil and left the filter, as I did not want to try and stab it with a screwdriver and twist, as if THAT failed... Jeez. So I left it. (Just an excuse to change the oil sooner AGAIN anyway.)
I went out after and bought a filter tool that has a band that locks on the body, That tool has to be the smaller one, of the two sizes available...
Once the shield is off, the drain plug and the oil filter are easy to see.
Anyway, got it back together. Added the new Mobil One, Started it up. smooth... really smooth. I love the way an engine sounds and feels (through the wheel etc) right after an oil change.
So it was a success. And being a lazy 62 year old bag, i did OK. Several other older folks saw me down n the garage and mentioned it is not very expensive for a oil chage place... LOL!
I told them I enjoy doing it... (that is what I tell myself..)
Afterwards, my manual tranny starts from a stop are easier. The engine seems to hesitate a tiny bit less. And it may be i am just getting in tune with the clutch and all, but it is getting easier to start off and not have to give it much extra gas to takeoff.
The final thing is a oil drain tray with a small lip (like mine) is NOT very good. you want a big tall-walled tray to catch the oil. It is really spitting out sideways hard, when the plug is pulled. (and naturally as the oil drains, the stream begins to arc more naturally down. until empty..)
[woot]
[woot]
