81 - 100 of 104 Posts
· Registered
I owned a 2012 Se five speed for a little over 3 years. I got my ST a month ago. Was somewhat careful about breakin and did not stomp on the gas hard until I had a 1,000 miles on it. When I did finally stomp on the gas rolling from 50mph I have to say not much (chaply anyway) could be done to make the regular Focus as fast except maybe a 100 shot NOS? LOL And then it would only be similar/close but no cigar... [woot]
Off the line it is a lot of finess anyway.(due to lack of traction). But from a rolling start. JEEZ the ST is a monster. [angel]
· FF Affiliate
Anyway all foci are FWD... good luck over 300 hp..
I have built dozens of Focus over 300HP to the wheels and there a blast to drive , use some common sense and you dont have much wheel spin at all
· Focus Preacher
The only RWD Focus I've seen is the V8 Focus...
Better than FWD ;)
· Focus Preacher
It's either the car or the driver, I know plenty of super high hp FWD that can catch traction. Tom has built some super solid cars, I'm sure his run real well.
Problem often is not traction ... this can be solved with wider tires ...
but with torque steer
Higher than 300 hp it becomes harder to mitigate...
That's why you don't see a lot of manufacturer using the FWD layout for performabce cars
· Registered
Wait, didn't the Diamond Star Motors / Eagle Talon or whatever they were named FWD cars come from the factory with > 300hp at the wheels? That would put SAE net HP somewhere around 330.
I remember hundreds of stories of how they were running sub 14 second 1/4 miles straight off the dealer lots. And with something like a $0.06 washer or $0.08 turbocharger modification they were running sub 11 second 1/4 miles, or so were the stories.
I believe they hold the record for quickest accelerating FWD cars in stock configuration.
· Rubber Side Down
I used to know a guy with a >500hp boosted Integra and it was amazing because he set up the entire car properly.
