1 - 8 of 8 Posts
Hi, I bought a 2008 Focus SE/S. I need a driver's side door. I know someone that is parting out a 2008 Focus SE. Are they the same body style car? Just wondering if the door is the same?
Thank you, Dan
Old Phart
That would depend an whether they are both 2dr cars or 4dr cars - the only two options that year.
Old Phart
Mostly "trim" & optional equipment AFAIK, check under the tail for rear sway bar - that varies between models, not positive on what cars that year. Def. on SES, Prob. on SE.
You'd need Window Stickers to be sure of differences, each trim level also had options avail..
The only major difference is if one has leather and the other has cloth. The interior door panel would have a matching insert.
Otherwise they should be identical.
The only instances where the door would not work is if one Focus was an "S" trim with manual windows and mirrors or if one Focus was a Coupe.
I thought the coupe had the same front doors? Maybe not I haven't really checked them out. But the only different was already stated, that and color matched handles.
Coupe doors are longer in length.
1 - 8 of 8 Posts
