1 - 3 of 3 Posts
I picked up a stock rear swaybar for my wifes SE. It didnt come with the center brackets, it does have the center bushings and endlinks.
I crawled under the SE to see if the install would be the same as on a ZX3.
The SE doesnt have the center bracket mounts like my ZX3 welded on the crossover tube.
Four questions?
1. Has anyone installed a rear swaybar on a SE that didnt have a factory one?
2. Where do I get the swaybar center brackets?
3. Whats up with the missing center bracket mounts on the SE?
4. Am I screwed?
Questions:
1: Don't Know.
2: Not sure, Dealer? I think that aftermarket would have been a better choice in this case.
3: Cost savings most likely.
4: Depends on what you paid for the factory bar. Can you return it? Sell it?
Do a search for "stabilizer bar" on this site and others. I remember seeing instructions online somewhere on installing an aftermarket bar.
Good Luck!
Rear sway bar
Yes, I installed the Performance Sway Bar (22 mm) on my sedan. I used regular exeaust pipe clamp. I just grinded them on the inside to be able to centered the link on suspension. they work fine no problem at all.[:)]
1 - 3 of 3 Posts
