1 - 6 of 6 Posts
I think this is a good question for this forum. If not well, Sorry in advance!
When I 1st got my Xcal2, the SCT forums contained info posted by forum members that the Xcal2 could not actually hold 3 tunes (although I can no longer recall the specific problems that may occur).
To this day I have avoided loading 3 tunes to my Xcal2.
Is this true? Is true under specific circumstances? Totally False?
Thanks! [race]
I have 3 on mine with no problems....
You can also combine live load and other apps to change the tunes in it, I did without the PRP installed on the computer; I have two on mine, but it does have the capacity to hold three at a time wit option to overwrite them.
Anyhow, your tuner should have given your tunning file in other to reload if required. Good luck.
Rich
Token Engin-nerd
I have 3 on mine currently and only use two of them
I have overwritten them (by my own doing in liveload) twice
What you probably read was about our older X2's and newer processors.
The device itself is designed to hold 3 files. However, the older devices had less memory than newer ones and when used with some vehicles (07 auto. mustangs for instance) they could only hold 2 files. This was fixed on the newer devices by adding more memory.
On your car though, both new and old will hold 3 files no problem.
1 - 6 of 6 Posts
