MK3 Maintenance
Engine oil: check dipstick at least monthly.
Oil change schedule attached below.
Oil Filter: FL-910S
Engine coolant: check monthly; only top off with Motorcraft Orange Antifreeze; check coolant strength every 6 months; replace at 100,000 miles
Automatic transmission fluid: Check fluid level at each oil change; Replace every 150,000 miles
or
Manual transmission oil: Replace every 150,000 miles
Spark plugs: replace every 100,000 miles
Belts: inspect and replace as needed at 100,000 miles
Battery connections: check every 6 months
Fuel filter: a lifetime fuel filter is integrated with
the fuel tank. Regular maintenance or replacement is not needed
Washer fluid check: check fluid level monthly; use a methyl alcohol based fluid in cold climates to avoid feezing
Wiper blades: replace if degraded
Cabin air filter: replace every 20,000 miles-Motorcraft FP-70 Cabin Air Filter
Air filter: Replace every 30,000 miles- Motorcraft FA-1908
Tires: rotate and check tread depth at each oil change
