1 - 2 of 2 Posts
Great day!
Looking for help please. Anyone know, in RWD format (yes, probably only the Ranger 2.3l).
On the hunt for a RWD oil pan/wet sump for a 2.0l 05-07 Duratec. The question is, will the depth of the pan be much different, or can I use a stock Ford or aftermarket RWD sump vs $600 euro option please?
I also require a lower/shorter valve cover, which only seems available from
Hope yall have some fun
Jim
Check out the NC miata, 2006-2015. They use the same 2.0 duratec and will likely have the oil pan and pick-up tube you're looking for. As for a low profile valve cover, I've never heard of one. If you're doing a rwd set-up, you might need to use a NC miata timing cover because your power steering, ac, and alternator might have to be moved for the intake manifold.
1 - 2 of 2 Posts
