1 - 20 of 33 Posts
Greetings all! I apologize for the long post. I'm hoping someone can give me some direction. Hours and hours of googling and reading through forums like this one have given me a lot of possible things to look at, but no real firm starting point.
I have a 2005 ZX3 SES I bought earlier this year. It ran great for about a week, then threw a CEL and started stalling out every time I let off the gas to come to a stop. I replaced the plugs. I cleaned the throttle body (sticky and gummed up) and the IAC valve. I would have replaced the air filter but it has a lifetime filter and the indicator is well within the green range. The car stopped stalling, but instead started idling high, 2000-2500 rpms. DTC said minor vacuum leak, so I pulled the intake manifold and cleaned the flaps, cleaned inside the block where the valves are, cleaned the TMAP sensor, replaced the pcv valve and tubing (which had a huge gash in it). In order to get the intake manifold off, I had to remove the fuel rail. One fuel injector came out with it, the other three stayed in the engine block. I replaced the affected o-rings. Put it all back together and it ran like a top.
I had read some good reviews online about Marvel Mystery Oil and since I could tell this baby hadn't received much love, I thought it would be a good idea to clean the fuel system. I read that MMO could be used in the fuel tank or during an oil change which I thought odd but figured it must be ok. What I DIDN'T read were the instructions, instead assuming it was like all other fuel treatment products I'd used, and dumped all 32oz in at the next fill up. Basically 6-8 times what I should have put in. About 90 miles of driving later, it started coughing and sputtering and shaking like it was going to fall apart. There was also an occasional loud "pop" coming from just behind the engine. When I pulled over, the engine compartment smelled like when you burn the ends of a polyester cord to melt them a bit so they won't fray. The serpentine belt had been shaken half off the pulleys and I had to pry at it to reseat it. I sat there and spent a few hours reading online, determined it must have been the overdose of MMO that caused my current woes. The consensus was that I should drain the fuel tank and put in fresh gas. I also read that the catalytic converter can be damaged if the car is driven while misfiring, so I got roadside assistance to tow me to my storage unit where I spent the night waiting for them to open so I could get my tools. Next morning I couldn't get my siphon hose to reach the fuel through the filler hose, so I drained the tank by connecting my siphon hose to the fuel line in the engine compartment, disconnecting the battery negative terminal, shorting the fuel relay, turning on the ignition key, then making contact with the negative cable about 500 times to get all the fuel pumped out. I also replaced my serpentine belt since the old one had sustained damage. I then put in 5 gallons of fresh gas, and many cranks later got the car started. Again, rough idle, sputtering, coughing, popping. And my serpentine belt fell off. (Over the course of this ordeal I've had to put it back on 3 times, and reseat it by prying at it 3 times. I'm assuming it's the roughness that jostles it off since when I'm careful to not let it run too rough it stays on.) I read a ton of stuff about what all this could mean, thought maybe I'd damaged fuel injectors, fouled valves or plugs, fouled oxygen sensors, ruined my catalytic converter. A friend suggested there still might be MMO in the system, advised putting in Chevron supreme with techron and a fuel injector cleaner, then drive it until the catalytic converter gets hot. So I did that. Drove it for 150 miles with only a couple of stops. Mostly on freeway with some in town traffic. And it only runs marginally better. It doesn't pop, or maybe I just turn it off before it has a chance to. I noticed that sometimes after I start it it'll rev up to 3000 rpms and stay there for a bit before settling down to cough, sputter, and shake. I don't know if that was happening before I drained the fuel, so I'm worried I damaged something draining the way I did. Also, as long as I was cruising 60-70 mph, it seemed to run smooth, though it lacked a little power. If I let off the gas and coast, occasionally it will keep accelerating, and I imagine that if I had it in neutral at those times it would be revving up to 3000 rpms on its own. Otherwise when I let off the gas half the time it'll surge and cough, the other half nothing. If I then apply the accelerator slightly, say to keep it at 45-55 on level highway, it bucks and surges. Once it's under a load and picking up speed it settles down. When it town, it coughs and surges most of the time, but occasionally settles down and runs normally. But very infrequently. Now the DTCs it's throwing are:
P0171 system too lean (bank 1)
P2195 O2 sensor signal stuck lean bank 1 sensor 1
P0128 coolant thermostat (coolant temp below thermostat regulating temperature)
P0420 catalyst system efficiency below threshold (bank 1)
So now I'm wondering if putting in too much MMO was just a coincidence, or maybe all this really was caused by the overdose.
If caused by the overdose, things I'm looking at include damaged/fouled or leaking fuel injectors, damaged fuel rail pressure sensor, damaged or fouled plugs, damaged or fouled O2 sensors, damaged or fouled catalytic converter, and gunk that's been loosened up and is now wreaking havoc. Also possible collateral damage if by draining the fuel as I did I either stressed the fuel rail pressure sensor or fuel pump too much, or confused the crap out of the PCM/ECU.
If a coincidence, I'm looking at all the above plus possibly the MAF sensor.
All hoses seem tight and well-attached. I pulled the vacuum tube off of the FRP sensor and the end of it did not smell like gas.
Does anyone have any ideas about what's going on? Am I missing anything? Any suggestions of what to try first? Second? Etc?
And what do you think of Scotty Kilmer's suggestion to clean the catalytic converter by putting in a gallon of lacquer thinner when the tank's half full and then running it at high speed for 150 miles?
Thank you so, so much, to anyone who chooses to give me some considered, pertinent advice!
I should also add that my car has the same hard to start issue that so many others have. So I'm familiar with what my fuel pump sounds like. And it seems to me that after draining my tank as I did, the pump doesn't run for as long as it used to when I turn the ignition to "on".
Also, when I say it settles down once it's under a load and picking up speed, that's only when I'm giving it quite a bit of gas. If I'm accelerating moderately, or slowly, it bucks and surges.
Just finished driving it across town. It's definitely backfiring. Not many loud pops from the engine compartment, but the exhaust is noisy like it has an exhaust leak, only it's not steady, it surges.
I sure hope someone here can help me!
Why I say it until blue in the face, you NEVER use add-in chemicals to cars. And I used to sell them.
You likely killed the cat with doing it, you CANNOT clean out a sooted up cat from oil going into it. Don't care what anybody says. The plugs and O2s are likely dead too.
You created a vacuum leak when you redid the TB and IAC. The high hanging idle. If you reused gaskets then the issue there. That TB can be easily warped to stick as well from overtightening it.
Look to those things before you look at the belt issue, the more you touch the worse it runs, I'd give that some thought.
I don't believe marvel mystery oil did it not at all.
I have seen people put gasoline in a diesel, and diesel in gasoline. Was the engine destroyed either time absolutely not.
Hopefully you used new gaskets for the intake manifold, and properly tightened things down.
Oxygen sensors are sensitive it's possible they could have been damaged.
Give this guy's channel a watch. Engines are a lot tougher than people think. He does this for fun and has a extremely successful YouTube channel doing so.
It's possible you could have damaged some sensors maybe the cat, but you didn't destroy your engine.
Unfortunately certain people on here post rude comments.
Nobody says the engine is ruined. I would have it running (right of course) in a short time.
When people put gas in diesel or the opposite they never put only a quart, the greater amount then kills or disables the engine almost instantly to not run long enough to hurt anything. The quart only amount did not do that, the engine was not disabled enough to not run and so much the worse.
Of course, somebody had to think to end up there. So hard.......the exact situational circumstances kill like they always do.
To whit:
'About 90 miles of driving later, it started coughing and sputtering and shaking like it was going to fall apart.'
You gotta read. Accumulative damage from the lesser amount, more rocket science.
Tough situation.
Have you purged the fuel system of all MMO contaminated fuel?
Some of the MMO may have clogged the fuel filter - you may want to remove it and check it for flow.
Have you pulled the spark plugs out to look at them?
Look at RFP using live data on your scan tool - what is it reading?
Look at the O2s using live data on your scan tool. Is O2S1 switching? What is O2S2 doing?
Paul
MMO should go through a fuel filter effortlessly, it mixes with fuel almost instantly. You just end up with oily fuel that will burn with a lot of soot. The extra soot is what poisons the O2s and the cat. The oil also covers up some of the fuel's volatility, or the ability to vaporize easily to have plugs light it off faster and easier. Why some of it is still burning in the pipe, the burn got slower and the wetted plugs fouled to add to that even more. The backfiring.
Yes throw a gallon of paint thinner in the fuel tank , while you are at it go get some def tank liquid and throw 2 cups in just to be sure. Thirdly send 2 upc codes to youtube to get your official youtube master tech patch.
I’m with Paul on this, check your live data. Likely just end up getting new O2 sensors.
Go ahead & change your fuel filter anyway, it’s cheap enough to do.
See about checking gas cap & fuel vapor system too.
my 2cents. Has the Fuel rail pressure sensor been replaced with the bosch aftermarket one. They always fail around 100k and any high milage car you see has the bosch one which works great. Also when you are cold and you hear a bit of an exhaust leak. It could be the header warped. My 2005 did. I think running MMO and cleanings pulls crap out of the tank so it can clog already restricted fuel filters. Also I don't think that much MMO in a full tank hurt anything. I tossed a dash in every cylindar once and besides a TON of white smoke nothing happened. My only code is from my warped header. I shaved it down enough that it doesn't sound like a straight pipe but it needs another 10 thousands before I think it will seal right.
when you are cold and you hear a bit of an exhaust leak. It could be the header warped. My 2005 did. My only code is from my warped header. I shaved it down enough that it doesn't sound like a straight pipe but it needs another 10 thousands before I think it will seal right.
My ‘05 2.0l has this leak as well. It’s louder when cold too.
How’d you get the header trued up?
Warning if we share heatshielding removing it before hand is required and will require damaging it. I wrapped my header so I don't have put it back. If you can find a shop do that for 100 bucks.. Otherwise a belt sander will probably do 90% of the work easiest. A small electric hand sander for like 7-8% that last bit will be all elbow grease and time. The 20 dollar aluminum leveling stick at Harbor freight is true. Take a feeler Gage to verify before purchasing. I glued dense foam to a mostly trued board for my overall leveling. Stuff some paper in too prevent Debris from entering cat. Be sure to disconnect lower exhaust before moving engine to prevent damage to flex. Good luck
The PO clearly told us the problem began when he added the oil, I don't know why people have so much trouble with that. Post #14 goes where the other guy went (post #4 and read the conditional situations given there as 'equal' but ARE NOT) and not thinking there, we are talking the difference in 5 minutes using a chemical vs. '90 miles' (NOT 5 minutes by any means!) or a chronic buildup and the two conditions are not relatable except in a world of those who do not understand differences or differential results.
No wonder things never get fixed around here.
MMO is not the cause of your problem. I've had tired engines that burned oil, and all I had was tranny fluid so eventually, the oil was 60%+ tranny fluid rather than oil, and no adverse effects. And MMO is sort of like tranny fluid. But anyway, I've run 20% MMO in many vehicles, and it's done wonders for sticky valve guides, and cleaning things up, running smoother. I put it in my fuel as well. I've used it in classic cars as well as modern OBDII cars, and never had issues. Before I found out about MMO, I used tranny fluid the same way--20% tranny fluid in the crankcase, and a measure in my fuel as well. I'm not saying everyone will have my success, but I'm not just spouting off woulda coulda shoulda's, this is my real life experience.
Some people have cars that live in spite of them rather than because of them, that would apply here for sure.
Why there are both good and bad life experiences.
And once again we are calling the OP a liar.
1 - 20 of 33 Posts
