just put in a air/fuel ratio gauge to discover i'm running extremely lean, only mod is a short ram. anyone have any ideas as to how i can correct this. i'd like to avoid buying new injectors if possible. thanks
That sounds more like your exhaust is clogged to me. If the engine was running too lean then you'd be hearing popping noises from the exhaust at idle.sleeping6spd said:i think it is running lean, because when i start from a stop it needs to be up around 2 to 3 k rpms to move and it idles a little rough
