1 - 4 of 4 Posts
the rubber caps on my headlights that keep water and stuff away from bulbs came off and i am wondering if there is a special truck to get them back on. any help will earn rep
theire harder than hell to put on-- i do drive a 04 Zx3 but maybe its the same idea--- you pretty much have to force them on.....they should stay on with sucktion-- i really hoped I helped but that's all ive got
A little lubricant around the inside edge should help them on. That or some good ole spit ;-)
Make sure you apply even pressure around the circumference, kind of like lug nuts in a star pattern, and bit by bit they'll go on. Test them afterwards to make sure they wont just fall off, I lost one after not checking.
i didnt find them hard at all, just work your way around on them, pressing down along the rim, bit by bit, making sure the outer part folds over not into the hole
1 - 4 of 4 Posts
