1 - 5 of 5 Posts
wats up guys. well just wanted to know what the rpms limit should bein an auto se sedan cause on my tach ive just managed to reach 3000 and whooped on a ranger edge.3000 is the most ive gotten to. i think it should be more but thats why im asking.maybe ididnt install it right?
Discussion Starter · #2 ·
by the way, i hooked up the green wire from the tach to the negative wire in the distributor. i also knew something was wrong cause i used the "TACH I NEVER KNEW I HAD" and it read something totally diffrent from the aftermarket tach
you need a tach driver we have newer elctrical ignition system tach driver costs like $70
GreyRice WOoT!
shit man i get mine to 6k rpms...
hey pin 48 (on the ecu) works as a tach driver for us just shove the signal wire in the 48 slot and your grooving thats what i did and it works, but i think i read somewhere its not exactly accurate but seems to work fine with me expect rpms go down slow i dont know if thats from the signal or just the engine
1 - 5 of 5 Posts
