I have been thinking about getting the royal purple tranny fluid. they have the synchromax(something like that) but it doesn't specify a weight. This might be a dumb question but im a little confused.
I went with the royal purple. I read on here that you need to buy 2 quart but i only bought 1. Is it allright if i go ahead and drrain by other fluid and put just a qt in?
The supplement calls for 2.1 so you technically can get by with 2 bottles. I bought 3 because I'll do another dump & fill rather than having a flush done initially which cost mad coin. So the answer is a minimum of 2 bottles
I bought three becuase I saw 2.1 and using the third for the .1! Maybe I'll skip the .1 give the bottle to my buddy so he only needs 1 ot I'll use the .9 to flush. Guess it depends on how charitable I feel the day I *finally* put it in...
When you drain it there will probably be an amount left in the tranny so 2 bottles will probably work and mixing some OEM residual with Synchromax shouldn't be a problem. Me...I'll do another drain and fill sometime this summer just to clear that out.
