Which engine does she have? If it's the SPI (split port injection), you might want to try to sell it before it self destructs.
Check to be sure that you correctly tightened everything down at the air cleaner assembly, and nothing is out of place.
Remove your spark plugs, clean, re-gap, re-install or replace if needed. Use anti-seize on the threads to prevent future issues.
We don't have many Utahns on here, but one of them had an SPI with that same problem for a while. Now it's getting a V8. Unfortunately, the SPI engines tend to drop a valve seat in the #4 cylinder sometimes causing complete engine destruction- and always causing an expensive engine repair. If you can work on engines yourself, you can remove the cylinder head, take it to a head shop, and have a head job with new valve seats. That has worked for other SPI owners on here.
I don't think that's your problem, but I feel like I have to warn new SPI owners about the potential of having that problem. Your problem sounds more like a PCV valve vacuum line. The idle is probably a bit low as well. Check all the simple stuff like that first.
